leomon
3
Hi guys,
im new here, and my friend bought an imac, its really sweet.
I am really sitting on the edge of buying it. I am an avid PC user, and have been all my life.
However i am a music fanatic. After reading this forum, my speakers arent really that new, they are the old Z-5300's but they are still great in terms of sound.
They dont have optical output, just the standard 3 x 3.5mm connections.
Left center and right.
what is the cheapest way to hookup these speakers to the imac, while still having 5.1 sound ie. for watching movies
An external sound card is not necessarily the best answer. This permanently uses up the FireWire port on your Mac. I would recommend the Creative Decoder DDTS-100. Sadly, Creative no longer sells this item, but I'm sure you can find one on eBay
The Creative Decoder allows for 7 inputs - 3 optical, 3 stereo, and 1 coax. Its up-mixing quality is superb, and I have enjoyed it very much so for the past year.
Christopher
My brother has this attatchment that goes on the end and turns the three speaker ports into just a single 3.5mm port it came with his dell 5.1 speakers. so maybe you could get one of these it works really good.
I don't know about this but my brother has this attatchment that goes on the end and turns the three into just a single 3.5mm port it came with his dell 5.1 speakers.
That's not 5.1 That's at best 2.0 blasted out of 5 speakers and the sub. Which means 5.1 DVDs and games and such won't sound nearly as good because it's not 5 separate channels.
so the only way to work around this is buy an external video card like that fire wire thing?
That sucks. Why would apple put such a nice monitor perfect for video and movies and stick ONLY a optical port in it. So many people out there have the 3x3.5mm speaker inputs.
Now i gotta spend like 100$ just to enjoy 5.1 sound?
err
music is important to me. I need that 5.1 thx speakers workin.
I live in Canada to so i can only get this used, ebay or amazon with the shipping and duties...
The iMac line out doubles as a digital optical 5.1 bitstream or standard analog stereo.
Your speakers are designed to take multichannel analog which is a cheap alternative for surround sound, designed to be used with hardware that outputs in analog - such as typical gaming surround sound cards.
Apple doesn't cut corners as a rule, so if you want PROPER digital surround sound, you will need to invest in the appropriate hardware.
I suggest you replace your speakers with another 5.1 set that accepts a digital optical input. The alternative would be to buy a second hand 5.1 receiver with optical input and the appropriate connections to be able to connect it to the 5300 speaker ports.
Aarghhh
i get i have no choice to tack on another 100$ for a imac purchase if i want quality sound.
1600$ i could get a quad core 2.4 with a 8800GTX card sigh~..
I use a Creative DDTS-100 with the Logitech Z-5300e speakers. It works pretty well.
I bought a DDTS-100 from eBay in 2005 and it failed a few days later. It was still under warranty, so I got it replaced by Creative and it's worked fine since.
And what exactly is the point of using 5.1 for music? Nearly every music source is 2 channels, with the exceptions being DTS CDs and DVD Audio.
