The Cockney Rebel
macrumors 68040
3,595
4,746
As per the title?
I’m still new to AirPods Pro, so don’t recognise the chimes that sound when switching between sound modes.
Is there a way/setting to allow the AirPods Pro to actually say what mode you’re switching to?
Thanks in advance.
I don't believe so, but it will be obvious, especially if you pause the audio before switching. The noise-cancellation mode will feel pressurized (and obviously quieter) and Transparency mode will sound like the room is mic'd up all of a sudden.
Reactions: The Cockney Rebel
Thanks. I was asking, because I had my setting to switch between all three modes.
Now I’ve unticked “off” you’re right, it will be obvious which mode I’m in.
If I want to switch it off, I’ll just use the settings app on my phone.
Reactions: usagora
Yes, I have mine set the same way (to toggle only between noise-cancellation and transparency). And the easiest way to turn off noise-control settings is to open Control Center, long-press the volume level indicator until you see the options for "Noise Control" and "Spatial Audio", click "Noise Control", and then click "Off".
