lclontz
4
First time Mac-owner here (though I've used them quite a bit). I just bought a used Quicksilver 733 G4 that seems to be having a weird problem. It powers up and runs fine with VGA, but plugging anything at all into the ADC port (whether a studio display or a Belkin DVI adapter) seems to kill the power. Nothing will turn on at all as long as something's plugged into the ADC port, but as soon as you pull the cable out, it works great.
Any thoughts, ideas, help? Thanks!
Lord Blackadder
macrumors P6
May 7, 2004
15,678
5,511
Sod off
What video card are you using?
The ADC port is basically a DVI port with built-in lines for power and USB to the display.
Strange issue...it would be great if you had another video card to test with but it seems to be a video-card related issue.
If the machine refuses to actually power on when the ADC port is connected to soemthing, be careful - there may be some sort of power-related issue that could have devastating effects if left unchecked (it might not be powering up because the breaker on the PSU gets blown due to an over-heavy load/short circuit).
lclontz
4
Thanks...
It's the stock card that the machine came with -- I'll have to check the specs to see what it is. What's strange is, if anything at all is plugged into the ADC port, there's no powerup whatsoever. As soon as I pull the cable out, it fires up fine. I can use it all day on the VGA port, but I'd rather have DVI if it's possible.
I tried it on a couple of ADC monitors with no difference and now a DVI monitor with the Belkin ADC-DVI adapter.
Sun Baked
macrumors G5
May 19, 2002
14,941
162
Check the cards ADC port (and cables) for bent pins, could be something shorting it out.
lclontz
4
The card is a...
GeForce2 MX w/ 32MB of RAM.
I'll check for bent pins. It's a work surplus machine, so I know it's been hooked to a Studio Display before (that's what we have there). Hmmm... thanks for the ideas. Seems it's more complicated than I'd hoped it would be.
