I've got an iPhoneX and iPad Pro 12.9 both running latest IOS 4.3. and an Airpods Max with firmware version 3C16.
In my iPhone's bluetooth settings, and with APMax's 'Automatic Head Detection' set to ENABLED, and 'Connect to this iPhone' set to AUTOMATICALLY, the APMax initially functions correctly & stops playing when the headphones are removed, and resume when back over my ears, and when I play something on my iPad, the audio automatically switches from the iPhone to the iPad, and vice versa.
The problem begins after I put the APMax back into its smartpurse (I mean case) which disconnects the bluetooth connection to the iPhone and iPad. If I then take the headphones out of the smartcase, my iPhone appears to recognize the headphones again (rotating image of headphones appear on iPhone screen) and APMax showing up as connected in the iPhone's bluetooth settings, yet unable to re-route the audio from the iPhone to the APMax. The only way I'm able to get the sound to come from the headphones is to disable 'Automatic Head Detection' in the phones' APMax Bluetooth settings. Strange that this happens 8 out of 10 times, sometimes connecting but then disconnecting again, which makes me suspect this may be a (flaky) software issue. I even reset the Airpod Max to factory default and re-paired the headphones to my devices but this didn't help. Anybody else here experiencing similar issues? Until resolved, I'm stuck having to use the APMax with Automatic Head detection disabled.
