rogueGT
41
25
Hi all,
finally received my space grey AirPods Max.
Agree with all the comments on this board, they sound amazing - nice and open.
Listening on Tidal - the sound quality cannot be beaten.
However, half way through a listen, i got slammed with a massive crackling (at full volume) in my left ear cup - i quickly pulled the headphones off, and i hope there isn’t any damage to my ears.
Has this happened to anyone else ?
AppleRobert
macrumors 603
Nov 12, 2012
5,729
1,133
Did that happen listening to Tidal? That service is finicky, dropouts and what not especially with Android. I dropped it, went to Qobuz and couldn’t be happier.
  • Love
Reactions: JasonHB
rogueGT
41
25
Yes you are right - i was using Tidal , and the crackling sound did suggest that it was trying to connect / pair with the iPad Pro when doing so.
However, this is clearly a hardware failure of the APM , as there shouldn’t be such a loud crackling / static sound .
Seems like a faulty sensor which got triggered when i put the headphones on and it tried to pair / resume Tidal .
I’ve sent this back to Apple and getting a replacement sent over the next few days.
rogueGT
41
25
thanks for recommending Qobuz.
I have never heard of it before. how does it compare with Tidal with regards to music collection, mixes, their algorithm, their UI ?
AppleRobert
macrumors 603
Nov 12, 2012
5,729
1,133
I hope it works out for you, what you described has happened to me with Tidal with various headphones so I wish you luck.
AppleRobert
macrumors 603
Nov 12, 2012
5,729
1,133
I listen strictly to jazz and classical music, Qobuz has plenty.
The UI is fine, no issues on my end with that. The sound quality is superb, I cannot get enough honestly. I spend lots of time listening, all I watch on TV is sports of which I am a fanatic. No sound, just watch the action and listen to music with Qobuz.
rogueGT
41
25
Are you saying that with various headphones you get crackling sounds from Tidal ?
or just that you have connection issues ?
I’m thinking that crackling ‘ static sounds coming from the headphones are a defective hardware issue
jterp7
macrumors 65816
Oct 26, 2011
1,292
161
Precovid youd easily walk into an apple store for them to take a look. My local stores basically require a week wait at this point which is pretty unacceptable imo...were yours from apple direct?
mmomega
macrumors demi-god
Dec 30, 2009
3,888
2,101
DFW, TX
Hi all,
I had the crackling thing, one ear only when I intially put them on. The crackling was with just switching between Transparency and Noise cancelling.
I held down the 2 buttons until they force restarted and I've never heard it since and I use them almost daily.
UBS28
macrumors 68030
Oct 2, 2012
2,893
2,340
Hi all,
Try to do a factory reset and see if the problem appears again.
I had some early bugs too but after a few factory resets, it has been working solid.
rogueGT
41
25
I’m in Melbourne Australia. No i didnt’ go direct to Apple, i just got a refund on the APM, and then immediately ordered another APM Space grey. - should be arriving in 3 days.
