JirkaCink
9
Czech
Hello, I need some advice.
When I start using Airpods Max with the Airpods max microphone on my mac for example in app Discord, the sound gets worse.
Is there any solution to fix this problem? For example, in the software settings ?
I don't want advice like: Buy a microphone.
Hey,
does goes like that only for discord or also whit calls, or meetings in Teams/Zoom for example ?
This happens because Bluetooth has two modes: one for listening to higher-quality audio, and another for both listening and speaking through the microphone. When Bluetooth switches to the second mode, the quality of the audio that you're playing is reduced until the microphone is no longer in use.
The only setting you could check is this:
Reactions: Grobaouche
