x Shadow Dragon
102
Are their any problems that could/would occur if the MB fans were turned up? How much should i turn it up? (using SMfancontrol, i think its called)
Long term? I don't think anyone knows yet.
Theoretically, I image you speed the fan's wear to the point of failure. But does increased fan speeds reduce the heat ware on your processor/innards? Maybe.
<shrug>
