pep
2
Hi guys,
I have a perfectly working applecsript for TextWrangler (below: all the stuff between the first else and last end if) and only wanted to make it activate textwrangler if i work in another application; if i'm in textwrangler i want it to run the rest of the script. however, when i try to run this the applescript editor gives me an error complaining that "Expected “end” but found “on”." referring to the "on ComputeTempFileName(originalFile)" line.
I'm new to this... and none of what i tried worked.
Would you have any idea how to fix this? thanks a lot. Josef
if name of current application is not "textwrangler"
tell application "textwrangler" to activate
else
tell application "TextWrangler"
set thecontents to the selection in window 1 as string
set theOriginalFile to file of document 1
if thecontents is "" then
tell text window 1
select line (startLine of selection)
end tell
end if
end tell
set thecontents to thecontents & return & "erase temp.do" & return & "exit"
set tempFile to my ComputeTempFileName(theOriginalFile)
my write_to_file(thecontents, tempFile, false)
tell application "Finder" to set filename to tempFile as alias
tell application "StataSE"
activate
get name
end tell
if name of application "StataSE" = "StataSE" then
tell application "System Events"
tell process "StataSE"
set frontmost to true
tell window 1
get name
end tell
if name of window 1 = "data editor" then
tell window "data editor"
keystroke "w" using command down
end tell
end if
end tell
end tell
activate
open filename
end tell
end if
set c to container of originalFile
set t to (c as string) & "temp.do"
end tell
return t
end ComputeTempFileName
on write_to_file(this_data, target_file, append_data)
try
set the target_file to the target_file as text
set the open_target_file to ¬
open for access file target_file with write permission
if append_data is false then ¬
set eof of the open_target_file to 0
write this_data to the open_target_file starting at eof
close access the open_target_file
return true
on error
try
close access file target_file
end try
return false
end try
end tell
end write_to_file
end if
Problem 1 is functions like ComputeTempFileName and write_to_file need to be top level, that is, they shouldn't be indented.
You should rewrite your script to work something like:
Code:
if name of current application is not "textwrangler" then
	tell application "TextWrangler" to activate
else
	domybidding
end if
And put the guts of your script into "on domybidding".
Also, learn how to use the [ CODE ] [ /CODE ] tags. It makes reading these things a lot easier.
Also, you might want to rework that try block in in the write_to_file function. You might get an error but you won't know how to fix it.
mt
First post this in the programming forums.
Also use
PHP:
 tags (or code tags).
I tried to compile your code, but you've got so many if statements, try's and tell's that it is impossible, since you didn't indent anything.  From what I can tell, it looks like you have messed up your if statements.  You need to format this code correctly and use indents to visually show how your if's and end if's go together, your try's and end try's go together, etc.
In a phrase, this code is a mess.  :)
Thanks a lot MT, I'm new to this, but i eventually figured out:
Code:
	set appname to name of the first process whose frontmost is true
end tell
if appname is "TextWrangler" then
	domybidding()
else
end if
on domybidding()
Code:
else
	domybidding
end if
mt
