KratosKilla
209
35
I have used a Fos Power 3.5 mm to Toslink cable with my 2015 iMac. I tried to use this cable on the new Mac Studio and it does not stay in with it only being recognized as a headphone with no sound.
I used HDMI to my Yamaha receiver and it works but requires an extra phantom display running. The sound also goes off when I put the screen to sleep.
I attempted to use the USB-C to 3.5mm jack with the Fospower cable and it didn’t recognize anything.
Is there any cable I can buy that will enable good audio without a video connection coming over? Has anyone else been able to use the 3.5mm Jack on the Mac Studio to get the audio to work?
Falcon_64
Oct 26, 2017
103
153
Been using it since day one. The 3.5mm port on the Studio is not optical/mini-toslink though, I believe Apple dropped that some time ago.
Reactions: AlphaCentauri
PianoPro
Sep 4, 2018
511
385
You are trying to use an optical (Toslink) cable. It is not an optical output. Use a regular audio cable with a 3.5mm stereo plug for analog audio out.
If you want digital audio to your Yamaha you will need a USB to Toslink or Digital Coax converter. Something like this:
KratosKilla
209
35
Thanks! It's weird my old iMac supported optical from 3.5mm with the linked cable.
I'm guessing the Mac Studio abandoned this capability. I think I'm going to lean towards the optical. I actually have a Scarlett Solo. I just tried to use RCA cables through the line outs to my Yamaha RX-V373 with the connecting to my Mac Studio via USB, but I don't know if there is an IN. It's just silent.
