DrSarah
122
123
Vlaardingen, The Netherlands
Hello Fellow Apple users,
I am noticing I am not having a very long battery life when I am connected to a external display.
When I use the MBA without, I have like 14+- hours but when I am connected with a display it will last +-4 to 5 hours.
I do use the laptop in clamshell mode and running It with Amphetamine (which is unreliable as dirt though but that's a different story)
without a charger.
Do you guys also experience this behaviour? I would really like to use the Mac all day at work without having the power adapter plugged and ruining my battery, even though they say it doesn't hurt it. (it does, did it 4 months with my MBP 2020 and battery capacity was 90% already).
EDIT: it happens on multiple monitors. A 1920 x 1200 at work and a 3440 x 1440 at home.
jdb8167
macrumors 601
Nov 17, 2008
4,859
4,599
without a charger.
I don't understand why if you are plugged in to a monitor, you aren't also just plugged in to charging? Once I'm at a desk with an external monitor, I can't imagine not taking advantage of the desk to recharge. Not to diminish your problem but I suspect that Apple sees it as a low priority since most people using an external monitor will also be on a power adapter.
DrSarah
122
123
I don't understand why if you are plugged in to a monitor, you aren't also just plugged in to charging? Once I'm at a desk with an external monitory, I can't imagine not taking advantage of the desk to recharge. Not to diminish your problem but I suspect that Apple sees it as a low priority since most people using an external monitor will also be on a power adapter.
As i said it does matter. It degrades my battery. It did on my mbp 2020 in 5 months.
Reactions: Internaut
toxotis700
Nov 23, 2020
37
29
no it doesnt.... we all do the same and have no problems.
Maybe it was a coincidence
TrueBlou
macrumors 601
Sep 16, 2014
4,531
3,619
Scotland
without a charger.
Just out of curiosity, have you tried it without using Amphetamine? If not, give it a bash, using the built-in energy saving features in place of it, just to see what difference there may be.
Internaut
macrumors 65816
I did notice my battery seemed to drain a little faster when plugged into a monitor... Not a big problem for me because I can plug it in at anytime once the battery is between 20 and 70%. I wouldn't plug my laptop in simply because it's connected to a monitor on the principle you should look after your batter if you want it to be there for you when you need it.
Edit: I would add that my M1 Air is connected the monitor via a an unpowered USB-C hub (HDMI -> Hub -> USB-C and that gets a little warm.
Damien M
Nov 18, 2020
you need the powered apple usb c to cdmi plus usb with charging $69 or noname clone $10 from amazon or similar
or plug the charging cable in slot 2
