Brunof19
2
Hi, I have a problem. I have an iPhone 14 Pro Max for about 3 days now, everything is fine except one thing.
I am on version 16.3.1 and while I am using the mobile the battery drains slowly, about 1% every 10 minutes using social networks, but the moment I lock the mobile I lose between 1-3% in a matter of few minutes. I need help as I don't know if it is hardware or software problem. Thank you very much for your help.
Idkcurlyfries
Mar 6, 2023
I have an iOS 16.0; iPhone 13 pro and it’s like overnight the battery is suddenly draining. Last night before I put my phone down to sleep I had a decent amount of battery but in the morning my alarms didn’t go off because it died and it never happened before. I don’t know what’s going on either
kirbalo
Jan 21, 2022
20
10
Did you look to see if anything (app, etc.) is using battery when it's just sitting in "sleep" mode.
Apple_Tiger
Jan 23, 2023
659
897
You mentioned Social networks. Could it be possible that the app you are using could be the culprit? Have you tried deleting that app and let it sit and see what happens?
turbochgd
Sep 9, 2022
210
490
Go into Settings > Battery and you’ll be able to see in the graph (hours will be listed) what was using your battery the most while it was off during the night.
It’s also possible since you just got the phone that it’s still settling in with all the things it does behind the scenes. That could account for the additional battery drain.
Reactions: iosholic
Brunof19
2
What happens to me is like the battery I spend during use is not updated until I do not lock the phone, it's super weird.
No, no application is reflected.
It does not happen during the night, it happens to me during use, that until I lock the phone does not update the remaining battery correctly.
I've had the phone for 3 days now, I don't think it's an indexing problem.
