Voski
43
I dropped my iphone and it fell right on the bezel so on one corner it no longer sits flush with the back cover. So I think i need a bezel and back cover.
So I also had another question are the phones serial numbers related to their color? So if I got another color would the serial number reveal the true color?
Thanks!
Doing this your self will be very hard are will void your warranty. Just wait for a big issue, like the silent/ringer switch to break, hairline cracks in the plastic back, or something. Then when you have a big issue, you can get it exchanged.
Hmm... I was hoping to do that because there was dust under my screen before I droped it. But now I am worried that they will say since I droped it that they will not fix it because I caused any damages.
