carlsson
620
533
Apple are following some kind of standard; That if you connect something digitally (eg HDMI or DisplayPort) the sound volume should be altered on the digital device (at least, this is what I've read about it).
I bought a monitor that connects via DisplayPort. It has built in speakers. I cannot change or mute the volume on this monitor from the keyboard because of the above. This is extremely stupid and makes my life a lot harder.
I have tried some applications (Soundflower and Audio Mate) but the issue isn't resolved.
Do any of you have an advice? I mean, there shurely *must* be a way to override this (you are after all able to change volume from within many applications)!? I am willing to pay money for a third party app that solves this problem. According to Google, we are quite a lot that wants this.
I have written feedback to Apple, but I'm sure they don't care about this (they are quite narrow-minded when it comes to standards, which normally is good thing)...
Any help is welcome, this is driving me nuts!
/andreas
[MBP 15" 2011, OS X 10.11.4, Samsung S34E790C Curved 34" 21:9]
The only app that works around this is Sound Siphon AFAIK... $40. I used the Demo to try it out, it really works well.
But, as it would be a one-trick app for my use as in listening to music while I work, I used that coin to pay down on a bit of Schiit - a Modi 2 Uber.
Yes, that's the app - but, download the demo from the developer's web site. The demo doesn't have all of its features enabled - I think - but it does have the one feature you're looking for enabled. The setup was really simple in that in the app's Preferences I simply chose the "Displayport" output in the pulldown menu. Really, QED, and it worked immediately, with no lag, and without a reboot.
I know that I wrote that I opted for an amp/DAC instead, but you could look at the $39 price as being a lot cheaper than a couple of hours of therapy! :D And, I'm helping with "output" - not "input"!
Reactions: carlsson
