wonga1127
339
Wishing for a magic bus.
I am sort of confused on how 0.17 Ghz can mean $5000 more but 0.16 means only $300 more. Are there any differences between the 1.83 Ghz and 2.0 Ghz MBP's other than speed?
The 2.0 model has more vram, other than that it is all the same.
1.83 GHz MacBook Pro
15.4-inch TFT display with 1440x900 resolution
1.83GHz Intel Core Duo with 2MB shared L2 Cache (1)
667MHz frontside bus
512MB (single SO-DIMM) 667MHz DDR2 SDRAM
80GB 5400rpm Serial ATA hard drive
Slot-load SuperDrive (DVD±RW/CD-RW)
ATI Mobility Radeon X1600 with 128MB GDDR3 memory
2.0 GHz MacBook Pro (2.16 GHz option available
2.0GHz Intel Core Duo with 2MB shared L2 Cache (1)
1GB (single SO-DIMM) 667MHz DDR2 SDRAM
100GB 5400rpm Serial ATA hard drive
ATI Mobility Radeon X1600 with 256MB GDDR3 memory
Duff-Man says....not to pick on the starter of this thread, but really...two clicks at Apple's website would have answered the question...c'mon people..use your brains and at least make a bit of an effort to find your answers before starting a pointless thread....oh yeah!
