Just curious if using the MBP while plugged in at your desk continues to put normal wear on the battery?
You would think that once the battery is fully charged the best way to extend the life of the battery would be for the computer to power itself directly from the power supply and bypass the battery as a power source.
Does anyone know if it continues to degrade the battery while you use the MBP while plugged in?
