I got my new 3.06GHz iMac last week. The first had to be returned due to dead pixels on the screen and the guys at the Apple Store exchanged it
The one they exchanged it with however started to make a strange vibration/rattling noise today which appears to be coming from the lower left cornor
I thought it might be the HDD but I don't think it is
The noise comes around every minute or so and then disappears after a few seconds
Is this the GPU fan or is it a normal noise the Mac should make?
Thank you
Edit
It is a fan. I've just shut the Mac down while the noise was active and you could hear it stopping
Is this the GPU then?
Thank you
Edit
