Mic-M4c
139
27
Paris, FRANCE
Hi all !
Today I've proceeded to the long awaited upgrade of the WiFi and BT in my Mac Pro5,1 (mid 2010) Monoprocessor 6-core @3,33GHz SDRAM 48GB@1333MHz Radeon RX 560 4Go
> I've replaced the original WiFi by this one : BCM94360CD
> I have fully disconnected (USB alim and antenna) the original BT module, let in it's place :
> the 4 antennas have been correctly connected to the new WiFi+BT module
and everything works fine in Monterey 12.3 (with OpenCore)
EXCEPT ONE BIG THING : the FRONT FAN (and only him) runs at full speed fews seconds after I've pressed the Power Button and never stops :(
I tried to :
– reset NVRAM/PRAM > no effect
– same problem under Mojave, Catalina, Big Sur, Monterey but WiFi and BT work fine under all these macOS.
I checked with Macs Fan Control and I see that :
No way to manually change the fan speed.
I need you help please, to fix this front fan problem.
Thank you all in advance.
Guillaume
You probably just poked the fan connecter a bit or applied too much pull on the cable and now the connector isn‘t seated properly anymore.
Disconnect it completely, clean it, reconnect it.
It‘s the 4-pin plug right next to the WiFi/BT module.
Reactions: Mic-M4c
@arw
Hi and thank you for your suggestion. I will proceed tomorrow and write here the results. Thank you.
Any other advices ?
