cuzo
macrumors 65816
1,162
304
any guide on what to disable and what to run to maximize IOS battery?
Safari for some reason uses almost 40% (audio) and I don't know what the issue is.
Thanks
Please, just use your phone as it was mentioned to be used. Sure, you can turn off all the time bluetooth, wifi, cellular, iCloud sync, but if you do so why do you need then an iPhone? Also, no matter what you do, battery life will always seem too short.
