A few things to check. Did you attach the external antenna? Have you tried reorientating the Airport station?
If your walls have mettle studs, instead of wood, you will get significantly less signal strength.
Also, if the signal is just dropping, perhaps you are experiencing some kind of interference (like a 2.4 Ghz phone). It's unlikely to be the primary cause, as you also are having trouble finding the network. If interference is the cause, try interference robustness, which does nothing to the range or power, but does help with some kinds of harmonic and sporadic interference.
If you try everything, moving the Airport, etc, then perhaps you might want an external antenna or two. A single directional antenna can help some, but 2 good antennas is best. Perhaps even an Airport express as a bridge/repeater.
[The following is taken from a previous post I made. Pardon the recycling of text.]
You need to diagnose the problem first. Get a program like
Kismac or
iStumbler or
MacStumbler so that you can get better metrics on your signal strength. iStumbler now has a Widget that connects to the program if your running it.
Kismac is my preferred wireless tool. A nearly static graph with 5 levels of information isn't as good as one that has the potential for hundreds of lines of resolution over time. You can find the "sweet" spots as well as dead spots in your house with these tools. You can find other networks that might be interfering. It might help you position your network hardware better. If you choose a directional antenna, which I think might be too much trouble, these tools will help you figure out how best to align it. It's also nice to have a good stumbler for when your out and about.
I have a cantenna, and it does boost signal strength, but it is very directional. On my iBook (now dead) I got a noticeable gain, but I had to run the cable through my keyboard. From the router it should help, but then again, a Pringles antenna or any directional antenna set up works best when both units are directional. If your a DIY person,
www.Airshare.org has instructions. You can also Google it. It's nice getting a starter kit. The Cantanna is also anodized now, but I don't think it's worth it.
Link to a DIY Yagi in a Pringles Can.
Hawkingtech offers a nice little portable external wi-fi router (
HWL2A) (with high-gain antenna) that will double as a wi-fi locator (looks a little like a StarTrek tricorder). This tool can be used as an external router that can directly connect to your mac. It's on my list to purchase, but I haven’t used it. It's also pricey.
Lastly, and perhaps
most importantly, for better wireless reception, build a
AFDB. Also good against certain high level surveillance methods used by the
U.S. Government and by
alien entities.
