larrymassive
24
Hi there i have gone through all the guides to fix this problem of edge not working after jailbreaking but i cant understand how to work the windows "putty" program is there anyone out there who can type out exactly how this fix is done? theres lots of the same guides out there but they are a bit confusing. I am on a legit iphone o2 uk contract jailbroken iphone
cheers
joshstanley91
Dec 9, 2007
8
Installer
Hi, you need to install installer on your iPhone, Then go on it and go on network folder and instal EDGE, WIFI Application
This should help.
P.s Can You Help Me, Im The One That Says "SIMFREE PROBLEM"?
Thnkas
