EQPT:
1TB WD Elements micro usb External hard drive, about 3 years old, well used.
PROBLEM:
iMac OSX, won't appear on desktop, was fine until a couple of days ago, micro usb socket seems a little loose.
- Won't mount to computer.
- asked to "initialize, ignore, eject"
- shows in disk utility as hard drive only (factory name. not name I gave it)
- No sub volume listed, so can't run disk repair or verify, won't eject (i guess because it doesn't mount)
The hardrive light is on, the drive vibrates/ starts up as normal and dies down when i choose eject.
SOLUTIONS TRIED:
- New cable - SAME THING
- Different Mac x 2- SAME THING
I can't remember if I formatted it as Journeled/ Fat 32 etc... I think it was formatted for mac use only.
I haven't connected it to my PC yet as i'm worried it might format it.
I've read online you CAN'T take this model out of the casing and stick it in a HD dock because of parts soldered to it.
I'm going to run disk warrior , but don't expect it to help as I have no volume listed.
I have nearly 1GB of data I DESPERATELY need back, but have made my peace with it being gone at this point if need be.
INFO IN DISK UTILITY
Name : WD Elements 1023 Media
Type : Disk
Partition Map Scheme : Unformatted
Disk Identifier : disk1
Media Name : WD Elements 1023 Media
Media Type : Generic
Connection Bus : USB
USB Serial Number : 575834314132313430323137
Device Tree : IODeviceTree:/PCI0@0/EHC2@6,1
Writable : Yes
Ejectable : Yes
Total Capacity : 1 TB (1,000,202,043,392 Bytes)
S.M.A.R.T. Status : Not Supported
Disk Number : 1
Partition Number : 0
Disk Description : WD Elements 1023 Media Total Capacity : 1 TB (1,000,202,043,392 Bytes)
Connection Bus : USB Write Status : Read/Write
Connection Type : External S.M.A.R.T. Status : Not Supported
USB Serial Number : 575834314132313430323137 Partition Map Scheme : Unformatted
IS IT ALL OVER?
PLEASE HELP!!!!
PROBLEM:
SOLUTIONS TRIED:
Type : Disk
Writable : Yes
Ejectable : Yes
Disk Number : 1
IS IT ALL OVER?
PLEASE HELP!!!!
