carbonmotion
983
San Francisco, CA
Hi, before I began my tale of woe, let me tell you what system i have ...
I'm running on OS 10.4.6 on a 1gz Powerbook G4 15" Aluminum model. I had a spare 5.25" 30 gb Maxtor UATA HD, so i bought a no name USB 2.0 enclosure (200gb max) and stuck the maxtor in there as an external... all good right? sure it works like charm. I bought a Western Digital 160 gb harddrive and stuck it to the same enclosure and no matter what i do i t wont mount on my powerbook... the read/writing and power light are both lit but not mounting occurs... anyone with any advice? I check some mac message boards, and it seems like mounting WD disks is tricky in general. I really need help, please someone help me?
CanadaRAM
macrumors G5
Did you set the 160 Gb drive to Master with the jumpers?
You have Erased the drive with DiskUtility, yes? A new HD won't mount until it is Erased or Partitioned and has a Mac volume to mount.
If yes to both of the above, it could be that the noname case can't provide sufficient power.
carbonmotion
983
San Francisco, CA
its a 12 v dc power... i dont see that as a problem
i dont see it in disk util
and it is set to master single
generik
macrumors 601
Aug 5, 2005
4,116
Minitrue
CanadaRAM said:
"12 VDC" doesn't tell you how much current it will deliver before it goes unstable...
Formatted NTFS is a problem for Macs, because Macs cannot write to an NTFS volume.
NTFS volumes do mount as read only.
