nickyj182
180
Morehead, KY
I have a Polaroid i733 digital camera, and I lost the USB cable to it. Obviously I need to replace it, i've scoured the internet to find out what type of USB cable I need. Any ideas? Thanks!
Actually we have that type of cable, the port on my camera is very tiny, smaller than that USB cable that you linked to.
I looked around on the Polaroid site, but I didn't see anything. Perhaps you could give them a call?
I would try them first. Otherwise, I have seen a more expensive kit that has multiple ends, so something might fit. I should say I have NOT tried this, this is what I could find, though. For example:
http://www.cyberguys.com/templates/searchdetail.asp?productID=13782
But I would call Polaroid first, they would know best and at least you know it would be the right cable. Good luck!!
