twistedlegato
macrumors 65816
1,494
My power charger wont work! and i have tried plugging it into a MILLION different oulets....And i only have 11 minutes left!??!!
Any sujestions?
j26
macrumors 68000
Mar 30, 2005
1,754
726
Paddyland
Check are any of the cables worn or frayed.
I had a similar problem before and it was a loose cable which eventually burnt out. I ended up having to get a new adaptor.
4nr-
Oct 5, 2006
210
Göteborg, Sweden
try taking out your battery and then inserting the power cable, and see if it runs then. There might be something wrong with your battery.
