encaputxat
9
Hi!
I'm using the imac before the aluminium, intel core 2 duo. My wireless connection doesn't work, when I connect to my net they says timeout, i have password with wap, other machines like macbook or powerbook works fine. In menu bar the list of airports aviable isn't stable (It'ts possible the wifi antena is broken?)
Other thing, I have a dvd blocked, and I cant eject. Can I eject with a paper clip o other trick?
Thanx for all, and sorry for inglish, I am from spain greetings:apple:
Eject is next to F12
Hi!
Did you mean something else for the DVD problem - mine just works as advertised?
I can't help with the other problem except to say that I also have WAP and it works fine. It connected the first time and it has reconnected each time I have switched off the machine.
Restart your iMac with mouse button pressed. This should eject the stuck disc.
