MacAztec
macrumors 68040
3,028
San Luis Obispo, CA
I remember a while back someone had information on how to restore a battery once it can't hold a charge. You take it apart, and there are a bunch of little batteries that you can buy in it, and you can rebuild it and it works good...
Anyone got information on this?
Erm, you mean play around with the internal cells? Sorry I can't help with a guide but I strongly recommend you don't do this. Not only could you ruin the computer you plug it into, you could also really hurt yourself. :eek:
Yeah that sounds dangerous. If you do something wrong it might explode :eek:, or short the system your trying to power.
