jauhari
149
6
Hi All,
I want ask about my :apple: MacBook Pro batteries power.
Everyday, when I was finish using my MacBook Pro, I never shutdown. But only doing sleep. The MacBook Pro led still dim. And I didn't use this MacBook Pro for 12 hours. When I lid :apple: MacBook Pro the battery power in 100%
And When I logging again in the morning, I check my battery, they show the status 85%. Is it normal? it's look like my sleep mode eat to much my battery power (15% in 12 hours) :(
Is it possible to fix it? that I mean make my MacBook Pro use less power when sleep. Maybe only os 2% in 12 hours?
Or? How to set the best configuration on :apple: MacBook Pro when the machine sleep?
*:apple: MacBook Pro Santa Rosa 2.4 with RAM 4GB
Hi All,
That sounds about normal in my experience (10-15% in 12 hrs of sleep).
I've never shut my macbook down since I got it at the start of January this year.
Sleep mode takes away around 10-15% (as given above) depending how much stuff is still going when I put it to sleep, turning the airport & bluetooth off does make a difference, especially if you're going to me moving out of range of he network you're currently in anyway.
That is one of the best things about Macs. I work in IT support, and it always amazes me how many PC laptops can't hold a battery when in sleep mode. They also wake so much slower than a Mac.
