Well, so I downloaded and installed Temperature Monitor and iMac Fan Control - mainly for observational purposes and not for toying around with the fan speeds and I've got some questions. Mind you, I haven't tampered at all with the fan speed settings, just installed Fan Control. Here are my readings (while browsing the internet with Safari and doing a chat via iChat):
Fan Speeds:
CPU fan (desired) 1300 RPM / (current) 1530 RPM
HD fan (desired) 2100 RPM / (current) 2099 RPM
DVD fan (desired) 1300 / 1298 RPM
Temperatures:
CPU Heatsink: 92°F
Internal HD: 108°F
Internal DVD: 95°F
GPU Heatsink: 107°F
Are these, under the circumstances, normal readings?
Thanks in advance for your replies.
Fan Speeds:
Temperatures:
CPU Heatsink: 92°F
Internal HD: 108°F
Internal DVD: 95°F
GPU Heatsink: 107°F
