I own a 9.7 inch iPad Pro. Some basic questions:
1. Can I use the US 5-volt AC block to charge this iPad? Is there any reason not to do so?
2. I see that the larger adapter is a 10-volt adapter. I have been using this to charge my iPad, and I believe this is the better choice, but I don't understand why.
3. Now that I am traveling to Europe, I have a 5-volt Type C (fiat with two round pins). This seems comparable to the US 5-volt, is that correct?
4. Finally, I guess I need a 10-volt version for Type C. Does Apple sell this product? Or is it available only as part of the Apple Travel Kit? Is it only available as standard block with international slide-in adapters, or is there an Apple product that is a single unit?
Basic questions, but I am confused and I welcome your explanation. Thank you.
