sh.1_8
9
I bought my 11 pro max smart battery case on the 18th of January and been using ever since. I opened the console app and checked the battery capacity of the smart battery case and saw that it was at 1403mAh but the max capacity of a brand new case should be 1430mAh.
Is this a normal thing or should I return it and get a new one?
  • Haha
Reactions: Fred Zed
I believe that if you do decide to return it- it will most likely happen again with the replacement
it's very incremental that it shouldn't bother with performance.
I have my smart battery case since June of last year and still works fine btw
