Floaaa
107
459
Battery health is at 100%. 2hrs 12 min for 43% reduction, so the screen on time would just be 5 hours. I just used notes and safari a bit.
Is 5 hours screen on for an 14 Pro Max normal?
Hard to say. Is this “normal” for you?
Obviously everyone will have different usage times and various factors will also affect battery such as reception strength, use on WiFi or cellular, screen brightness, etc. A lot of variables.
You need to see if this is typical drainage for your usage on a daily basis.
This is every hour when i sleep - what about this find my network? 😡 I have one airtag and the magsafe wallet.
