mariachi4
70
38
The standby, keyboard and notification click/ sounds are really loud suddenly. I already lowered the system volume to the lowest. Anyone got this issue as well?
I have the exact same issue on my 15 Pro Max on iOS 17.0.2. No matter what sound volume level the notifications and system sounds are set too, they are always sounded at maximum volume. Only when the phone is set to silent mode it stays silent.
Notifications also make maximum volume sounds even when my Apple Watch is connected, which is set to silent/haptic only.
Actually I think I've fixed it. Turn on Change with Buttons then adjust volume lower, then uncheck Change with Buttons.
Nope, ain’t working. The only way, at least for me, is to crank up the volume by side button, then the system sounds will be lowered. Annoying bug
So I contacted apple support and they said to turn of your Bluetooth and restart your iPhone. I had the same exact issue as well and this fixed it !
Reactions: Pug72
This seems to work for a while until I connect airpods to my iphone , the sound gets louder again.
Suddenly the text message notification of receiving and sending as well as typing is maximum volume. It doesn't matter if I turn the sound off in the settings and turn the volume to zero on the side. It will do this and then return to normal for a couple of minutes, then back to max volume. Ideas?I tried the bluetooth/restart but it didn't work.
