Hi I need to replace the battery on my iPhone se 2020. I am currently using ios15 on it and font want to upgrade to ios17 as I heard there is some sensitive eye issues with ios17 even on lcd. If I have my battery replaced with they update my iOS to 17 or will it do it automatically? I don’t want thst. Will that happen if I take it to Apple store? What if I try a different place to change my battery? If so any recommendations? Thanks fir tour info and help.
