Hello folks,
The problem:
I have a relatively tight case - the iphone slides in from the top. When the iphone is in the case the volume buttons are depressed as the case is so tight. When ever I receive a call, upon removing the iphone from the case to answer the call, the volume buttons are being pressed due to the tight case, which causes the call alert (ringtone) to cease. The iphone sometimes behaves strangely after this - as sometimes i am not able to answer the call successfully.
Does anyone know if there is a piece of software available (on cydia or installer) that disables the volume control on the side of the iphone during incoming calls?
Has no one else had trouble with this?
Cheers.
The problem:
Cheers.
