abley22
59
Hi!
My conserns with them is the battery, they need to be charged often and when the capacity goes under 80% they wont work proparly anymore,
My question is if they can be used with a worn out battery, while they are connected to a charger, or a usb battery when im on the run?
Personaly i use them most at home, so when i first bought them i thought it was possible to just use Jack cable without using batteries :)
Well i was thinking like it was a iPhone battery, that is not correct yes, with a small Battery like this that constantly use power no matter what you do i just imagine they wont last longer then my iPhone battery, if Apple do something with the draining they would last longer, now they use more battery in the case vs how much they spend power with the daily use.
Something isnt right when they drain the same % over night stored with or without the case, the case should saved power and made a difference right..
Reactions: wwinter86
