fBaran
218
The purpose of this code is to read from a file "input.txt" and everytime it see the word "print" it will print to console the word that follows it. If it sees the word "end" it should exit. Here's what I have so far, but it doesn't do it properly. It prints everything after it sees "print". Please help, thanks!
Code:
import java.io.*;
import java.util.*;
public class A6325 {
	public static void main(String args[]) {
		try {
			Scanner s = new Scanner(new File("input.txt"));
			while (true) {
				String st = s.nextLine();
				StringTokenizer t = new StringTokenizer(st," _.,-");
				boolean printIt = false;
				while (t.hasMoreTokens()) {
					String s1 = t.nextToken();
					if (s1.equals("print"))
						printIt = true;
					if (s1.equals("end")){
						if (s1.equals("print")){
							printIt = true;
							throw new RuntimeException();
				Scanner sc = new Scanner(st).useDelimiter("//s*print //s*");
				String printThis = sc.next();
				String print = "print ";
				int pIndex = printThis.indexOf(print) + 5;
				printThis = printThis.substring(pIndex);
				if (printIt)
					System.out.println(printThis);
		} catch (Exception e) {
			System.out.println();
Why not just do this? (assuming your words are separated by spaces)
Code:
	try {
			while (true) {
				String[] splitString = st.split(" ");
				for (int i = 0; i < splitString.length; i++) {
					if (splitString[i].equals("print") && i != splitString.length-1) {
						System.out.println(splitString[i+1]);
					else if (splitString[i].equals("end")) {
						System.exit(0);
printIt = true;
The problem is that you only get the exception if s1 equals both items which is impossible, it will either equal "end" or "print" but not both. Take out the second if statement
printIt = true;
If you do
Code:
if(s1.equals("end") || s1.equals("print")){
	printIt = true;
You should get the effect you want.
