Hey Macaddicts,
So one issue I'm running into with my 2019 16" I9 MBP is fan noise while I'm doing screen recordings via Quicktime. I borrowed an M1 Mac mini which was dead silent. Unfortunately a desktop wouldn't work for me as I have to be mobile. I suspect the new M1 Pro/ Max will be a lot better, but I wonder if I would run into less fan noise issues with the M1 Pro vs the Max, or if it would be the same. If it's the same I'd get the max. It would be great if Apple had something in the system preferences to throttle the processor to keep it quiet.
The MBA is always a possibility, but it's difficult to go back to thick bezels, and a smaller screen.
Do you think the Max would be more likely to spin up the fan than the Pro?
