I’m a wedding photographer currently using a MacBook Pro with an M1 Max (10-core CPU, 24-core GPU, 32GB RAM). It’s handling my workload pretty well overall, but I’ve caught the upgrade bug!
Most of my work is in Lightroom and Photoshop, where I rely heavily on bulk AI denoising and generative fill tools. Processing 300+ photos per wedding with AI denoising takes hours, which my current MacBook Pro manages but not without some delays.
I’m considering either the M4 Pro (14-core CPU, 20-core GPU, 48GB RAM) or the M4 Max (14-core CPU, 32-core GPU, 36GB RAM). Which setup would give me the most noticeable performance improvement?
Also, I regularly use the Apple Vision Pro for Mac Virtual Display, but I sometimes notice it isn’t as smooth as expected. Not sure if that’s an AVP or MacBook issue.
Thank you in advance for your help!
