AphoticD
macrumors 68020
2,306
3,487
Hi all, this is a long one, so thank you in advance to anyone who takes the time to read and may be interested in helping me solve this...
I am troubleshooting a stubborn Mac Pro 4,1 (Early 2009 base-model Quad Core 2.66GHz single CPU) that refuses to power on. I bought it as a "For Parts" machine for around AU$50 (Australia), during late 2023. The seller described the machine as problematic/intermittent. At first it did not appear to respond to power button presses or shorting the power-on pads. In my initial few days with it and after some perseverance of trying SMC resets, reseating components, swapping out RAM and GPU configurations, replacing PRAM batteries, and eventually pulling the main board and PSU out to clean, and open-air test, among other various techniques, I put it all back together and did eventually see it succeed in powering on and booting twice using the front power button. So, I thought I had made progress.. I shut down to swap out drives, and then went to power it on again, and it has never powered on again.
Pressing the DIAG button while connected to power shows 5V STBY light as expected. When I initially connect power, I see a quick flash of red at the CPU lights. If I hold the front power button (or hold the short of the SYS_PWR pads) and connect power, I get sustained red lights on the 2 CPU LEDs (indicating the front power button works and/or logic board is wanting to send a POWER ON state). There are no other signs of life otherwise in terms of fan activity or other diagnostic LEDs.
Initially, without any spare parts on hand to troubleshoot, my first thought was potential power supply failure, so I hunted around for a working replacement and imported a PSU from the USA for around US$90 inc international shipping.
Once the replacement PSU arrived, I promptly installed it and observed the same behavior as before (no response to power button or pads), so I tentatively ruled out the PSU as being the culprit (I still thought maybe it was possible both PSUs were faulty), and then tried hunting for a backplane/ logic board next.
The only nationally sourced replacement I could find at a non-exorbitant price was around AU$80. The seller sold it as untested, but claimed that it once worked, and they no longer had parts to test it. I took a gamble and ordered it. The replacement backplane arrived quickly and was a match in terms of part numbers and EEE code (AFAIK). I installed the backplane and put the machine back together again, to witness the same no-power behavior: Zero progress to date. I then tested combinations of both PSUs and both backplanes to attempt to rule out one thing or another.
My next logical step was the CPU tray, so I hunted around for a little while and did not find anything of a decent price which I could consider investing in, so I shelved the project for over a year. Then last month I spotted a 6-core 2.93GHz (single CPU) tray complete with RAM, claiming to be "Pulled from a working MacPro4,1 In perfect working condition". The seller accepted my offer and I got it shipped for AU$110 with 12GB RAM pre-installed, which I considered to be not-so-bad considering how much I had invested in total so far.
The replacement CPU tray arrived and was installed, but as you may have guessed, the Mac Pro is still a no-go and does not respond to power in any manner.
I then proceeded to test each combination of Backplane, PSU and CPU on hand, with and without GPU, and inside and outside of the chassis to see if I could potentially see any sign of life. Continuing to dig deeper, I studied the PSU pinouts and bench-tested the 12V and 5V lines while in PS_ON short. Both PSUs responded with solid, reliable looking readings, so I feel quite confident the PSUs are not at fault. Leading me to attempt to record my progress to document and share here for anyone who might suggest ideas...
Long story short, I’ve invested significant time and a fair amount of money seeking out and testing parts to attempt to isolate the variables, and I’m now trying to determine next steps, and/or how I can better determine exactly where the fault lies.
Are there potentials in my case where EEE code mismatches could cause the no-power state? Or could I have multiple marginally functional or failed parts?
System Overview​
I've tested combinations of the following:
2x Logic Boards / Backplanes​
  • 820-2337-A / Serial: J592900YZ1LTC / 630-9399 (original - I have witnessed it boot)
  • 820-2337-A / Serial: J591401AW1LTC / 630-9399 (sold to me as untested, but appears OK)
2x CPU Trays (Processor Boards)​
  • 820-2482-A / Serial: J5928021U4MFE / 630-9752 2.66GHz (original - 2.66GHz Quad Core)
  • 820-2482-A / Serial: J590802104MFB / 630-9752 2.26GHz (2.93GHz 6-Core - Pulled from a working system)
2x Power Supplies (both tested working via bench test)​
  • Delta DPS-980BB-1 A / Apple PN: 614-0435
All components are clean, contacts are isopropyl-alcohol cleaned, and the system is tested both in-chassis and open-air configs.
To recap what I’ve tried:​
  • Confirmed both PSUs deliver 12.3V (blade) and 5.1V (pin 13) are correct on rails while using jumper wire between pin 4 and pin 14
  • Confirmed front power button is functional (can be held while connecting power resulting in sustained DIAG LEDs)
  • Used SYS_PWR power on pads instead of button
  • Tried powering on with:
    • No RAM
    • No GPU
    • No HDD
    • 3 different known good GPUs
    • With/without front panel I/O board connected
    • With/without bluetooth and airport cards installed
    • Tried with/without PRAM battery
  • Tested with both CPU trays individually on both backplanes
  • Tried resetting SMC
  • Tried resetting RTC
  • Repeated cleaning of tray slot and tray contacts
  • Inspected pins / contacts at CPU trays OK. Clean, no corrosion, no bent pins.
  • Inspected all capacitors on backplanes and CPU trays - no evidence of bulging or leaking
  • Tried power-on using CPU tray without CPU, RAM or heatsink
    • As per Apple service manual troubleshooting steps, this should allow the fans to spin during power on but it won't POST – this could potentially bypass EEPROM or VRM issue or incompatibility to help troubleshoot backplane + CPU tray communication and POWER ON state.
Observations​
  • 5V STBY LED illuminates when power is connected and DIAG button pressed.
  • Shorting front panel power-on pads does not trigger any fans, LEDs, or appears to show any voltage rail activity
  • No PSU clicks/clunks when attempting to power on, which are clearly audible from the PSUs when I bench-tested shorting PS_ON and connected to power.
  • I have seen the original config boot twice in the past, but never again – so surely something here has the potential to work.
Questions​
  1. Are any of these parts potentially incompatible from an EEE code pairing perspective?
  2. Is it possible that both PSUs and CPU trays are fine but both backplanes have failed?
    1. Should I take another gamble and try purchasing another backplane?
    2. From the experience of others is this the most likely issue?
Goal​
I'm just trying to get one known-working pairing that will reliably power on, and ultimately POST, so I can then move forward with this machine, and put it to work.
At this point, my (limited) experience with the 4,1 is making my noisy old 3,1 seem rock-solid in comparison.
Any advice, verification, or compatible EEE code lists would be hugely appreciated.
Thanks for your help!
Questions​
No, you bought the right parts.
  1. Is it possible that both PSUs and CPU trays are fine but both backplanes have failed?
Yes, very possible, but right now you have to assume that the defect could be elsewhere.
The best way to identify is to borrow/buy a working Mac Pro and test one part at a time on the working one.
Since you probably have an intermitent defect, more on the side that once in a while works, you probably have to test for some extended time with each part, like running ASD extended test and powering on and off (including removing mains power for like 1 hour).
Like I wrote above, get a working 2009 Mac Pro, buying piecemeal is more expensive and is not getting you anywhere.
    1. From the experience of others is this the most likely issue?
People that repairs only one Mac Pro have a different experience from people that does that for a living and already have a test mule for testing all the parts.
The defect could be anywhere, not your case but for example a short circuited Superdrive made me completely tear down a Mac Pro twice and took me hours and hours of diagnose. Same thing with a leaked capacitor on the front IO board that made me crazy for an hour - sometimes is not the big items that go defective.
Btw some times even removing the shorted component, you still have to power it off from the mains for a long time until the fuses reset, sometimes takes a day.
Also, do you know if the backplanes are already cross-flashed to MacPro5,1?
You can't run a Westmere Xeon with a backplane still with MP4,1 firmware, the Mac Pro won't power on.
This is frequently overlooked.
Thank you for your reply, @tsialex — I greatly appreciate your insight.
I've continued troubleshooting with your comments in mind regarding potential SMD fuse resets and other fault conditions, but unfortunately, I'm still seeing no response from the system under any configuration.
To isolate the issue, I performed an open-air test using just one of the backplanes, connected to a known-good PSU. I tried both CPU trays, removed the PRAM battery, and let the board sit disconnected for several hours between tests to allow time for any polymer fuses to reset — but there was no change in behavior. No fan spin, no diagnostic LEDs, nothing.
Regarding the 6-core Westmere CPU I mentioned earlier — I removed the heatsink from that CPU tray (recently purchased) and discovered that the installed CPU is actually a W3540 (4-core, 2.93GHz), not the X5670 as advertised. I've contacted the seller about a refund or exchange, but in the meantime, since both CPUs are Bloomfield-class, either should be compatible with the Mac Pro 4,1 firmware and capable of booting.
Next, I plan to pull out the currently installed backplane and PSU, and open-air test all combinations of the two backplanes, two CPU trays, and two PSUs I have on hand. At this point, I'm leaning toward the possibility that both backplanes may be non-functional, which I understand is rare, but not impossible.
One remaining question:
I’ve read in a few places that it might be necessary to have the front panel board connected during open-air testing — potentially due to power draw expectations or logic signaling. In your experience, would leaving the front panel disconnected prevent the backplane from asserting PS_ON when shorting the SYS_PWR pads? I'm wondering if that might explain the persistent 3.8V reading at the PSU sense pins when attempting to power on.
Thanks again for your time and expertise — it’s been incredibly helpful. 
P.S To answer your question on whether the backplanes are cross-flashed to MP5,1. One I know for sure is original MP4,1 as I have seen it powered on in the past stating "Mac Pro (Early 2009)" in About This Mac, and the 2nd backplane is an unknown as I have never seen it booted).
Good question.
Since I always start first with known good/confirmed working anciliary components, testing first the CPU tray, then the backplane and only much later the front panel, I can't answer it, but I'll verify and get back to you early next week.
The issue with the defective front panel, after it shorted the backplane, everything seemed completely and totaly dead, I tought that it killed the backplane, but letting the backplane completely disconnected for the weekend solved the issue with the resetable fuses and started right away with my confirmed working front panel when I went back to work on Monday.
One thing that got me puzzled, when trying to make a dead Mac Pro to work again I found a piece of some type of conductive paper (probably from a pack of cigarretes) shorting both USB ports on the front panel, don't ask how and why someone inserted it, but now I always check for anything that may be tucked inside ports/slots/connectors.
You can never know if a children was playing near the Mac Pro or someone intentionally tried to kill it…
Reactions: AphoticD
Update on the thread... It's working! 👏
I had a sneaking suspicion that both backplane boards I had been testing were faulty, so I committed to buying a tested, known-good 4,1 backplane. I purchased from a seller in the US and paid international shipping, which when added with taxes, came in under AU$200. Which was still lower than what I could find in Australia.
The board arrived a few days ago, and I open-air tested the spare parts I had on hand with the board. I connected the (non-installed) PSU, and CPU tray (W3520 w/ 2x 2GB RAM) and jumped SYS_PWR to power on. The PSU made a satisfying clunk noise to indicate it was delivering power, the DIAG lights lit up and the CPU fan started to spin. It's alive!
Finally, I was able to see something actually working in this project. So I stripped the MP4,1 tower down, replaced the backplane with the new board, cleaned all the fans and internals, repasted the CPU and northbridge heatsink. Once it was all back together I powered it on (with a GT 120 GPU) and was so happy to see this Mac Pro 2009 finally making a chime, and showing a boot screen.. Such a relief after all this time and my many attempts of trial and error.
I have since upgraded the firmware to MacPro5,1 via an El Capitan installation (using steps: Apple Mac Pro 4,1 Firmware Upgrade to 5,1 in 2024), then installed High Sierra to get the next firmware update. I then took a GTX 680 2GB EFI flashed GPU donated from my MP3,1 2008, and ran the Mojave installer to finally get the BootROM version up to 144.0.0.0.0 — I am so impressed to see this update went smoothly, and the MacPro5,1 (!!) is now humming along happy and relatively cool (compared to my MP3,1) on it's absolute best Firmware.
Now that I have a working MP5,1, I have ordered an X5675 6-Core 3.06GHz 12MB CPU (to replace the Quad 2.93GHz W3540) for AU$29 shipped, which appears to be a good price. I believe the TDP should be lower with this CPU, the cores will be faster (and more of them), and should produce less heat overall. Plus, I will add 2x8GB of DDR3 registered ECC 1333MHz RAM, both of which should now work in this "MacPro5,1" - the RAM cost me less than AU$14 from a server pull.
I have confirmed that I now also have a spare PSU and CPU tray that both work, but that "Unknown condition" Backplane I took a gamble on last year was my loss on this project. I wonder if that unknown condition backplane might now show signs of life with my 5,1 flashed CPU tray... I'll test that theory next to confirm.
Considering this cMP was destined to go to landfill by the previous owner, I am so happy to see it now repaired and fully functional. I look forward to upgrading the CPU and RAM this week, and will then purchase an NVMe PCIe adapter and new SSD to remove the HDD bottleneck.
I have been considering an RX 570 4GB GPU to upgrade the card and then improve my options with OCLP — I want to keep power and heat down a little, which is why I think an RX 580 8GB GPU might be overkill (and likely not going to run any cooler than the GTX 680). I understand the GTX 680 limitations, and I am okay with running native Mojave for the most part, but will likely try Monterey via OCLP with this GPU once I get an NVMe solution.
Any thoughts on GPU preference for longevity on the cMP? Should I just stick with the GTX 680? Or upgrade with something like the RX 570 or 580 and push it to Ventura or Sonoma via OCLP?
Thanks again @tsialex for your help and words of advice.
Long live the cMP!
P.S. The 5,1 is humming alongside my 3,1 as well as a late '05 Quad G5, and a DC G5. They are certainly keeping my office toasty warm this winter :cool:
Reactions: LightBulbFun
Polaris GPU (RX 570/RX 580 2304SPs) and Monterey.
Anything newer will have issues with the required AVX2 instructions, not supported by the Xeon CPU of the MacPro5,1.
Reactions: AphoticD
I can't find confirmation in my searching, but will the RX 580 2304SP run off the mini-PCIe power connectors from the backplane? I noticed most of these cards require a 6-pin + 8-pin (theoretically 75w from PCIe + 75w + 150w). Is this safe to run with 1x mini-PCIe 6-pin to 6-pin adapter and 1x mini-PCIe 6-pin to 8-pin adapter? Or is it better to supply additional power?
This is the reason I am thinking the RX 570 or an RX 580 "2048SP" would be better suited, due to lower power requirement of just 1x 8-pin on the GPU which can connect via an adapter that takes 2x 6pin (Y-spliiter) through to 1x 8pin.
Buy a RX 580 that requires only 8-pin, then you can feed it from a dual mini-PCIe 6-pin to 8-pin. Never use a mini 6-pin to 8-pin, you will damage the backplane.
RX 580 2048 SPs or RX 590 GME, also have just 2048SPs, are not even supported by Apple AMD drivers.
Reactions: AphoticD
Excellent advice. I'll seek out the RX 580 with 2304SPs. Thank you!
A lot of people like the XFX RX 580, since is only 2-slots wide and not 2,2 like the Sapphire Pulse.
XFX, Sapphire and others also make the dreaded 2048SPs, so be aware.
Update on the restoration: The beautiful looking XFX RX 580 arrived, super clean, with 2x big (quiet) fans. It installed A OK into my 2009 MP5,1 and benchmarked as expected. I get an  logo boot screen, so the GPU must have already been flashed for Mac. The card connected to power via the "2x 6-pin to 1x 8-pin" adapter supplied.
I am awaiting the X5675 CPU and another 16GB of 1333MHz DDR3 registered ECC RAM to arrive to bump it up to a 6-core 3.06GHz Xeon with 32GB of RAM. I have also ordered a WD Black SN 7100 1TB NVMe SSD and a Simplecom EC415 NVMe M.2 SSD to PCIe x4 adapter (w/ alu heatsink).
Once these parts arrive I will install Monterey via OCLP and put this wonderful cMP to use as my primary, dedicated DAW with Ableton Live 12 to finally (hopefully) get over a massive case of writer's block. 🤞
Reactions: G4fanboy
Latest Update: The X5675 never arrived and was deemed lost in transit, so I got a refund and ordered an X5690 from China (AU$47 shipped with taxes), which arrived yesterday. I cleaned up the spare CPU tray and installed the replacement 6-core CPU, renewed thermal paste for the northbridge, and CPU, and replaced a thin strip of 2mm thick thermal padding between the tray and the heatsink.
The CPU upgrade was an easy drop-in replacement to bump it up from 4 cores to 6 and increase the speed of the 32GB of RAM from 1066MHz to 1333MHz with zero configuration — just a simple SMC + PRAM reset to allow the memory controller to re-negotiate speeds.
Geekbench 5 CPU scores jumped from 562 single-core / 2175 multi-core (W3540 2.93GHz) to now 683 single / 3576 multi (X5690 3.46Ghz), and temps (and TDP) run almost identical to the previous CPU. Compute scores are now 42828 (Metal) / 42249 (OpenCL), up from 39648 / 39792 which I would attribute to the increase in RAM speed.
Interesting to note that in my benchmarks the X5690 in this system is basically a match in multi-core performance to my MacBook Pro (13-inch Mid 2019), Intel Core i5-8257U Quad 1.4GHz.
To take advantage of the cMP tower design, I also purchased a new WD Red Plus 8TB 3.5" NAS HDD (256MB cache, 5640rpm, CMR, model WD80EFPX) for mass storage from a local supplier (AU$279 shipped) and partitioned it into 2TB + 2TB + 4TB. This spinning drive runs cool, and quiet alongside the WD_BLACK SN7100 NVMe 1TB SSD (boot/apps) and is fast enough for my audio sample libraries, photo libraries, and a Time Machine backup. No complaints so far.
The next thing on my list for this build is a PCIe 1x WIFI Adapter, which I have ordered (also from China) for AU$29 (shipped with taxes) to make use of a BCM94360CD WLAN module I have on hand from a faulty iMac 27-inch 2012, which is being scrapped for parts.
Overall, since getting past the faulty backplane hurdle (in OP) and upgrading this system, I have been super impressed with this Mac Pro. It's been enjoyable to work on and great to see it gracefully handle almost anything I run on it, from 32-bit apps and my Steam library in Mojave through to last supported versions of most modern apps in Monterey.
My current hurdle now is how to run VMware Fusion with this CPU on Monterey as there does not seem to be a supported version — I tried v11.5.7 (due to no XSAVE/AVX requirement), but it refuses to run on this version of macOS, and v12.2.5 and v13.5.2 which are both able to install and launch on Monterey, fail to start any VMs due to lack of XSAVE.
Are there MacPro5,1 users running later versions of VMware Fusion successfully, or do I need to move to UTM or VirtualBox instead? I've been using Fusion since v3 on Leopard, so I would be interested to know if it'll possibly work with this cMP.
VMware Fusion stops with Catalina and 11.5.7 with a MacPro5,1. You'll need to find alternatives.
Reactions: AphoticD
