Karpfish
661
ok, so i just got my mac pro todat and its great but i hav a problem. Whenever i turn it on or wake it up, all the lights flicker in the room so i know it is usinf a crap load of power. What should i do? Do i need a UPS?
Odds are that it a wiring problem.
It's fairly common in apartments and "tract homes"
It's also simple to deal with. First thing is to find out if the house wiring is the issue. If you CAREFULLY pull out one of the outlets in the wall. Look at the 2 or 4 wires running into the back of it. If they are screwed in, then this isn't your problem. if they are simply pressed into little holes in the back, then you have found the problem.
The thing with the outlets is this; when they are pressed into the little holes, they are only making contact with a tiny surface. (about 1mm x 2mm) When they are attached by the screw posts, they are making the best contact and the power flows better.
It's not hard to attach them correctly. You just need a set of wire cutters / strippers and a screw driver. The hard part is the fact that you have to so this to EVERY OUTLET in the house. :) It's not fun... I know, my house had 41 miss-wired outlets when I bought it...
I would highly suggest you turn off the breaker for that plug when you pull it out. Especially if you new to this.
Agreed.
But to the first reply, It is not just a common issue with apartments or tract homes. It will happen most everywhere with hig drawing electronics such as amp's, recievers, electric kilns, etc. Its an uneven flow of power dragging more to that outlet rather then letting the 120 some volts stream equally throught the house.
A UPS will solve the problem.
I disagree with this completely.
The box is still going to draw the power on boot. The UPS isn't going to give it more power than the house has. My UPS did not stop my lights from dimming. The only thing that did was to correctly wire all of the outlets.
