Gerritw
macrumors Chihuahua
2
Hello!
I have a problem with my macbook pro 2017 15 inch. The battery is draining overnight like crazy. Im talking about 40/50% every 24 hours even completely turned off.
I thought it was first the battery which was the problem. So i replaced the battery and calibrate it. It didnt work....
So I installed macOS and formatted everything. This also didnt work sadly
I looked into coconut battery if i could find any problems but that was not the case. It even says that my battery is in good health.
Other thing what i saw was that, when i shut down the macbook and turn back on after a couple of days its completely 0% but the date and time was the day when it reached 0%. Not the time that i shut down the macbook. Does this mean that, after i shut it down it doesnt completely shutdown?
I tried everything but with no luck...
What do u guys suggest to do?
Are you anywhere near a brick n mortar Apple Store?
NOT a "3rd-party provider", but genuine Apple?
If so, take it to them and have them check it out.
They might be willing to replace the battery for the standard charge ($199 US).
That's a very good deal.
You get
- a new Apple-labeled battery (not 3rd party)
- installation
- a short warranty
They might even be willing to do it "by mail" if you're not near an Apple Store.
If that's the case, give Apple support a call directly.
You get
- installation
- a short warranty
I live in The Netherlands... but it sounds good. will check it out if this option is available in The Netherlands
