ahmeetgungor
First of all I'm new here, excuse me if I creating this thread in a wrong place of the forum. The subject is, as you can see from the title above, I had a water spill on my MBA from the top left side. All of the ports are working as fine as normally, battery is working and charging, the keyboard works flawlessly but the machine runs so slow.. In Activity Monitor, Kernel Task goes up to %60 max, not like the others' 380% but it's damn slow. I did test AD and it gave me these two codes: PPN001 & PFM006 . I've also done PRAM and SMC reset but it's the same.. Nothing helped.. I ordered screwdrivers online, should I open and clean the logic board with tooth brush and alcohol or something?
Do you guys have any other suggestions?
