DarioK
17
Barcelona, Spain
I need your advice on this.
My MBA 1.6 which I have had since feb 2008 no longer has sound. If I try to adjust the volume I get a circle with a line through it and in system preferences I have 'device has no output controls' showing. I checked online also resetting the PRAM which worked only a few times but now it doesn't. I am unable to find the solution....
Some history: Earlier this year the hinges broke and after going back and forth with Apple they fixed it under warranty but at the time I was told that the logic board had also failed and so they replaced it.
I mention this because some of the possible 'solutions' I have read elsewhere refer to the logic board needing replacement.
Also a few weeks ago I tried out VMware Fusion with a legal copy of Windows XP, it had slowed my computer down considerably so I deleted it and all corresponding files but since then I have had no sound.
Is it a hardware failure? Given that I was able to resolve it before with a PRAM reset and repaired permissions or is it a software failure? If so should I wait to upgrade to Snow Leopard on the hope that it will be fixed?
All advice would be appreciated... I'm out of Apple warranty now but have store warranty for an extra year so should I return it or is there something I can do myself without opening the computer?
Thanks
wdean
Aug 22, 2009
9
Boston, MA
Same issue on my MacBook Air
Hi Dario,
I have a rev2 MacBook Air that I purchased new in November 2008 and the same thing happened to me about two months ago. I am just waiting for Snow Leopard to come out before having Apple fix it, since in both cases a clean install would be preferred.
islesguy81
Jul 23, 2009
19
Hi Dario,
Sounds like an OS X problem
Golden Master
Jul 7, 2007
30
I've just had my rev A MBA repaired after suffering the same problem. It was a faulty ribbon cable and a quick google suggests this is quite a common problem.
Some users report that a logic board replacement solved the problem. The tried this first with mine but tat wasn't the problem.
If you're out of warranty, a quick google will lead you to DIY fixes and to the part that needs to be ordered.
