AjTee
473
152
Gdańsk, Poland
Hello,
I have found that these two processes wake my laptop during sleep:
2022-07-21 06:01:36 +0200 Wake Requests [*process=powerd request=UserWake deltaSecs=75 wakeAt=2022-07-21 06:02:52 info="com.apple.alarm.user-visible-seld_processing,519"] (I have a lot of them during last 24h)
2022-07-16 12:11:03 +0200 Wake Requests [*process=mDNSResponder request=Maintenance deltaSecs=2689 wakeAt=2022-07-16 12:55:52 info="DHCP lease renewal"] (Have only a few of them)
What are these two processes? Can I disable them?
I have already disabled power nap, tcpkeepalive, screen time, proximitywake. Bluetooth is still enabled.
I have attached file with pmset -g log | grep "Wake Requests" command result.
Below you can find battery history.
Code:
xxx@MacBook-Pro-Jakub ~ % pmset -g
System-wide power settings:
Currently in use:
 standby              1
 Sleep On Power Button 1
 SleepServices        0
 hibernatefile        /var/vm/sleepimage
 powernap             0
 disksleep            10
 sleep                1 (sleep prevented by powerd, sharingd)
 hibernatemode        3
 ttyskeepawake        1
 displaysleep         15
 tcpkeepalive         0
 lowpowermode         0
Code:
xxx@MacBook-Pro-Jakub ~ % pmset -g assertions
2022-07-21 22:11:05 +0200
Assertion status system-wide:
   BackgroundTask                 0
   ApplePushServiceTask           0
   UserIsActive                   1
   PreventUserIdleDisplaySleep    0
   PreventSystemSleep             0
   ExternalMedia                  1
   PreventUserIdleSystemSleep     1
   NetworkClientActive            0
Listed by owning process:
   pid 312(powerd): [0x0000001400018014] 00:13:41 PreventUserIdleSystemSleep named: "Powerd - Prevent sleep while display is on"
   pid 312(powerd): [0x000000150008801f] 00:13:41 ExternalMedia named: "com.apple.powermanagement.externalmediamounted"
   pid 312(powerd): [0x0000001400098015] 00:13:41 UserIsActive named: "com.apple.powerd.ws.initialize"
    Timeout will fire in 78 secs Action=TimeoutActionRelease
   pid 366(WindowServer): [0x0000001700098025] 00:00:00 UserIsActive named: "com.apple.iohideventsystem.queue.tickle serviceID:100000906 name:AppleHIDKeyboardEve product:Apple Internal Keyb eventType:3"
    Timeout will fire in 900 secs Action=TimeoutActionRelease
   pid 611(sharingd): [0x00000287000182bd] 00:03:15 PreventUserIdleSystemSleep named: "Handoff"
No kernel assertions.
Please help.
Jakub
  • wake-requests.txt
I have no idea what's going on, but FYI...Apple Silicon machines don't have Power Nap. They contain efficiency cores that perform the same functions as power nap on Intel machines but at much lower power, and those tasks cannot be turned off.
This article may give you an idea of where else to start looking:
Power nap doesn't exist on M1 machines. It's an Intel only feature. For you, I assume '0' means more 'not turned on' rather than 'turned off.' Look elsewhere. Have you rebooted the computer?
My solution to "MacBook Pro waking up too much" during sleep:
Shut it down.
(really nothing more to write, it's simple and it works)
Shut it down.
But starting up for a shut down is totally different from waking from sleep. My Intel MacBook is able to sleep for weeks without the battery going to zero. My 14" MBP can't even make it one week. It's very disappointing to open the computer for use and find the battery fully drained.
