philosopherdog
818
669
So far I'm loving this new MBP. Awesome update. But the one thing I've noticed is that because I have "Tap to Click" enabled on the trackpad I am getting unwanted taps happening. The issue happens when I type and do not rest palms on the trackpad. Anyone finding this? The solutions I came up with are 1) turn off tap to click, 2) rest palms, 3) hold hands up which is fatiguing.
Reactions: mh`
Tap to click was the only source of pain for my new MBP so I turned it off. The good thing is that it takes way less effort to register a click than on a mechanical touchpad so it's not a loss. Now no more unintentional clicks. 3 finger drag is more accurate too.
Reactions: philosopherdog
3 finger drag is working. I found I need to keep the fingers closer to register the swipe. I'm going to try leaving tap to click on and see if I can figure out how to work around it. Just putting a palm across the trackpad makes it behave properly. I do like the trackpad overall. Coming from a mechanical trackpad it is much easier on the hands, but I find tap to click so much less painful.
Yes - I turned off tap to click too. The sensitivity - how hard you need to press to click - is configurable in Settings, and having it set to 'most sensitive' works well for me.
Reactions: thesaint024
