Last week I tried out bootcamp to see if I preferred it over Parallels (Parallels won
) however since then I am having problems with my mac's time. The main time shows correct although I had to manually change it, however all my browsers show they are ten hours behind (particularly noticeable on facebook) and every time I plug my ipad or ipod touch in the time on those resets to ten hours earlier as well.
The bootcamp partition was removed.
I have tried resetting PRAM.
I have gone to /private/etc/ and deleted the local time file.
Removed and reinstalled Parallels/Windows 7.
Is there anything else I can try?
Thank you.
Edit: It seems that half my computer is synced to Apple Asia time, even though the option is not checked. I am also unable to have the computer automatically select the correct timezone.
Thank you.
