I have an issue with my iPad Pro 9.7 that whenever you update the OS, it comes back with a black screen. No Apple logo on hard reboot, nothing. You can plug it in to my MacBook and it shows. You can “restore” it and it’ll go through all the motions including the screen coming up during the install process like normal. Problem is, when it’s done, you’re back to a black screen that makes it appear like a brick again.
One day, after mostly giving up on the thing for a few weeks, I plugged it in on a whim. A battery appeared on screen and the SOB took on charge, booted up as new. Thing worked great for weeks, until an OS update ruined it. Got it back, rinse, repeat.
The common theme seemed to be a full battery drain after a wired restore. I did see this turn up in a forum somewhere as being an odd solution.
So, my question is, I’ve got the darn black screen again and I wanted to know if anyone knew of a creative way to drain the battery so I don’t have to wait like a week or two to get this thing working again.
Thanks!
Thanks!
