Hi
So I have OWC thunderbolt 3 dock and OWC thunderbolt 3 20Gbps 2M cable.
I want to connect 2 displays, bot have DP inputs (one via miniDP to DP cable, another with usb-c to DP cable) and looks like I can get image on both of them only if I connect the one on usb-c port first and one with DP second, if not I will get signal only on the DP one.
Funny thing is that when using short, 40Gbps cable that came with the dock, I have no such problems.
Anyone alse has similar setup and noticed (or not) similar problems?
OWC tech told me, that this dock does not support 2 displays if one of them is not TB3 display, but I'm pretty sure that is not the case
