uguina
15
2
Hello, for a few weeks I have been seeing how my tablet lasts a lot for its battery. It is true that I use the Score match game a lot, but even with that, which lasts 3 hours or 4 hours on the screen, it is far from what It used to last.
I don't know if part of this problem comes from the last update they put in. Greetings. Sorry for my English
Then what is the problem?
my ipad's battery life is very short. It has gone from lasting two days using it a lot, to lasting about three hours of screen only. In both cases, I've been playing games, I don't know why this suddenly happens. Do you know a solution for this problem? Thanks
Have you looked at the Battery Health report in settings?
It shows you which apps are using your battery over the last 24hrs & 10 days. It also shows you when you last charged etc.
Yes, I have Looked that the games are using a lot of battery, but I used this apps always. I don’t know why I can only use 3 or 4 hours of screen on. Can I do something?
I erased the settings and data and reloaded the icloud backup, but the same thing happens to me
I have the same problem with my 12.9 (first gen) and there is nothing you can do... Battery wear is not linear, you'll have great battery life for a while then all of a sudden you experience a sharp drop and it only gets worse from there...
My ipad now lasts around 2 hours with my normal usage... I don't blame Ios 13 too much, although it certainly didn't help...
the problem is that my ipad is only one year old, it is the Ipad pro 12.9 December 2018. I don't understand why this happened. just like you can look at the health of the iphone battery, can you look at the ipad battery?
I suggest you call Apple, ask them to do a battery diagnostic.
if it’s degraded badly - they may be cool And warranty replace it.
use imazing (free version) to check battery health
Reactions: sparksd
The battery only have six months of warranty. I don’t know why the Ipad Pro only have 4hours of screen, but if the problem it is degraded, this has happened overnight.
Has it happened to you? I've only seen it happen to one person
Sorry, I don’t search this app, and with ipadOS the apps don’t know the battery status. Somebody know the app or other metod to know the battery status? Thanks
Imazing is a Windows/Mac app, not an ipad app and it works with IpadOS (connect the cable to you laptop)
Reactions: secretk
