zoran
macrumors 601
4,890
136
Chrome will not display fonts correctly in MacRumors.
Whenever I saw something like that at work, it was because someone was using a Font Manager to install a version of Helvetica that overrode the system version.
I did a standard fonts restoration (with FontBook) and i got the attached message... but still the problem remains.
Reactions: zoran
I did the sudo command and the issue when away... what exactly did that sudo command do?
It deletes and rebuilds the font database. Quoting the manual, typos and all:
databases will remove fontd System or User databases along with any cache files. Removing databases may cause the loss of font registration state: fonts activated outside the standard font directories, font faces disabled, and font libraries. New databases will be regenerated from fonts installed the standard font directories after the user logs out, restarts, or the fontd server is restarted.
-remove remove fontd databases for active user and system (used when no one is logged in and some background processes).
